If users in your database see the following error messages when logging in to your Ragic database using SAML SSO, here’s how you can troubleshoot.
If a user sees this message when logging in, this means SAML SSO login is disallowed in your database, and the user is not in the user group included in ignore denied login method for the user group. If you would like to allow that user to log in to your database via SAML SSO, please go to Company Settings and select that user’s respective user group in the "Ignore Denied Login Method for User Groups" field.
Please go to the attribute settings in your identity provider to make sure that your identity provider returns email addresses to Ragic using the correct format.
This means the user passed the IDP verification without using a password. If you would like to allow this method, please select "Yes" in the "Skip Authentication Method Check" field in Company Settings.
